English
How To: Remove a generic object from ISet
Summary
The Remove method on the ISet interface expects a single argument, an IUnknown pointer.
Procedure
This sample code removes selected objects from an ISet returned by the GetObjectsRelatedToObject method.
Code:
Dim pObjSet As ISet
Set pObjSet = pRelationshipClass.GetObjectsRelatedToObject(pOriginFeature)
pObjSet.Reset
Dim i As Integer
Dim pObject As IObject
Set pObject = pObjSet.Next
For i = 0 To pObjSet.Count - 1
If Not pObject Is Nothing Then
If pObject.Value(pObject.Fields.FindField("Point_Name")) = "Lafayette" Then
MsgBox "Before Remove: " & pObjSet.Count
Dim pUnk As IUnknown
Set pUnk = pObject
pObjSet.Remove pUnk
MsgBox "After Remove: " & pObjSet.Count
End If
End If
Next i
