English
Problem: ActiveX dynamically created shapefile layer does not render
After adding a shapefile to the map using the ActiveX connector, the layer shows in the layer list but does not render.
Cause
The mapservice does not allow dynamic layers.
Solution or Workaround
  1. Edit the AXL file for mapservice and modify the <MAP> tag to read:
    Code:
    <MAP dynamic="true">
  2. Refresh the mapservice in Administrator
