ERROR
License not available on AddExtension method
Error Message
When you invoke method calls on ESRI extension products from a stand-alone application, the methods fail with "license not available", even when you have a valid extension license.
Cause
Within VBA, you can supply a "0" as an argument to AddExtension:
pExtAdmin.AddExtension pUid, 0
From a stand-alone application, however, 0 is an invalid value.
Solution or Workaround
Substitute a variant for the "0" that is passed as the second parameter to the AddExtension method.
Code:
Dim pUid As UID
Set pUid = New UID
pUid.Value = "esriCore.SAExtension"
Dim pExtAdmin As IExtensionManagerAdmin
Set pExtAdmin = New ExtensionManager
Dim var As Variant
pExtAdmin.AddExtension pUid, var
Article ID:000004539
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
