BUG
Error while reading or writing logfile[]
If the data is in SDE, there are over 100 features in the selection set, and another component has the stream to the logfile open for reading, ISelectionSet:RemoveList and ISelectionSet:AddList fail with the following error message:
"Error while reading or writing logfile[]".
Cause
SDE does not allow the selection set to be updated while it is being used elsewhere in the system to iterate through the features.
Workaround
One way to hold on to the selection is by doing the following:
Code:
Dim pAV as IActiveView
Dim pEnumfeature as IEnumFeature
Dim pFeature as IFeature
Set pAV = pMap
Set pEnumFeature = pAV.Selection
Set pFeature = pEnumFeature.Next
Call the following after enumerating through the features to release stream:
Code:
pEnumFeature.Reset
Article ID:000004517
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
