English
Problem: ArcSDE Java API: Incorrect database username when connected to MS SQL Server as DBO
In Microsoft SQL Server a database username can differ from a Windows login name. For example, a Windows login user may be the SQL Server DBO. SeInstance.getUser() should return DBO as the username; however, it returns the Windows login name.
Cause
This is a known issue with the Java application programming interface (API).
Solution or Workaround
Resolved for 8.1 sp2.
