English
Error: ArcSDE Java API: SPECIFIED ATTRIBUTE COLUMN DOESN'T EXIST
Error Message
When using the column name returned by the SeLayer.getShapeAttributeName() method in a SeQuery, the following error is returned:
"SPECIFIED ATTRIBUTE COLUMN DOESN'T EXIST"
Cause
This is a known issue with the Java application programming interface (API).
Solution or Workaround
This has been resolved at 8.1.2.
