PROBLEM
Why are my OLE DB table field names truncated in the ArcCatalog preview panel?
** Fixed at ArcGIS 8.2 **
Some of the fields in my OLE DB table appear to have their field names truncated.
Cause
It is a known issue that field names in an OLE DB table are truncated to 31 characters in length in ArcGIS.
Solution or Workaround
Rename the field at the data source so the name does not exceed 31 characters.
Article ID:000004471
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
