English
Error: Application crashes when geocoding a dynamically geocoded feature class
Error Message
When geocoding a table of addresses to a dynamically-linked geocoded feature class within an ArcSDE database, the application crashes.
Cause
The ArcSDE locator that was attached to one of the existing dynamic geocoded feature classes has been deleted using the sdelocator command line utility.
This is a known issue.
Solution or Workaround
In ArcCatalog, delete all the dynamic geocoded feature classes, and their associated geocoding relationship classes, from the ArcSDE database.
