English
Problem: Numbers don't display properly when map configuration files are edited manually
I manually edited my map configuration file and now numbers don't display in their entirety. For example, "1,850,000" shows as just "1".
Cause
ArcIMS doesn't support separators, such as commas, in numbers.
Solution or Workaround
Do not use decimal separators in numbers. For example, use "1850000" instead of "1,850,000".
