PROBLEM
In ArcMap XY data can be exported to a shapefile, or as a feature class in a geodatabase. If the coordinate values for some of XY data records are blank, that is the X or Y values are null, and you export to a shapefile, the exported shapefile will contain points with coordinate values of zero.
This is a known issue.
Get help from ArcGIS experts
Download the Esri Support App
