PROBLEM
IFieldChecker.ValidateTableName never returns an esriHasInvalidStartingCharacter value
IFieldChecker.ValidateTableName never returns an esriHasInvalidStartingCharacter value even when an InvalidStarting character is the problem. An esriHasInvalidCharacter is returned instead.
Cause
The wrong esriTableNameErrorType value
is returned by the source code.
Solution or Workaround
When an esriHasInvalidCharacter value is returned, check the corrected name. If an esriHasInvalidStartingCharacter should have been returned, the corrected name will be the original name minus the first character. The corrected name when an esriHasInvalidCharacter value is returned has the invalid character replaced with a "_" in its original location.
Article ID:000004441
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
