English
FAQ: The MFC samples with MapObjects show memory leaks. How do I fix this?
Question
Answer
An incorrect method is currently used to create fonts in several of the MFC samples in MapObjects 2. These errors are noticeable specifically in the following files:
\CGuide\Step 10 - Printing and Preview\EasyMapView.cpp
\CGuide\Step 9 - Event Tracking\EasyMapView.cpp
\Common\MapHelper.cpp
Your code should resemble the following snippet:
Code:
CMoFont fnt;
// similar to CreateDispatch
fnt.InitializeFont();
fnt.SetName(TEXT("Wingdings"));
CMoSymbol sym(tLayer.GetSymbol(0));
sym.SetColor(moRed);
sym.SetStyle(moTrueTypeMarker);
sym.SetFont(fnt);
sym.SetSize(12);
sym.SetCharacterIndex(221);
fnt.ReleaseFont();
In sum, the following line of code..
Code:
sym.SetFont(fnt.GetFontDispatch());
should be replaced with ..
Code:
sym.SetFont(fnt);
Related Information
