English
Problem: Joining by location produces blank values or crashes ArcMap
When performing a join by location, ArcMap crashes or the columns appended are blank, NULL, or 0.
Cause
This is a known problem with larger datasets.
Solution or Workaround
Break the layers into several smaller layers. Then, join the smaller layers.
This issue has been resolved in ArcGIS 8.1.2. See 'ArcGIS Information' in Related Information below.
Related Information
