English
How To: Rotate text programmatically
Summary
Instructions provided describe how to rotate text programmatically. When setting the Angle property on an ITextSymbol object, the text does not move because the Angle property is not implemented. This is a known issue at ArcGIS 8.1 and 8.2.
Procedure
The workaround is to use the interface ITransform2D.
  1. Start ArcMap.
  2. Create a new UIButtonControl: How To: Create a new UIButtonControl​
     For more information on creating a UIControl, see the ArcGIS Desktop Help topic: 'Creating custom commands with VBA and UI Controls'
  3. Right-click the UIButtonControl and select View Source.
  4. Copy this code into the UIButtonControl's click event.
    Code:
    Dim pMxDoc As IMxDocument
    Set pMxDoc = ThisDocument
    Dim pLayout As IPageLayout
    Set pLayout = pMxDoc.PageLayout
    Dim pGC As IGraphicsContainer
    Set pGC = pLayout
    Dim pFont As IFontDisp
    Set pFont = New StdFont
    pFont.Size = 15
    pFont.Name = "Arial Black"
    pFont.Bold = True
    Dim pTextElem As ITextElement
    Set pTextElem = New TextElement
    Dim pTextSym As ITextSymbol
    Set pTextSym = New TextSymbol
    '''This line is ignored at ArcGIS 8.1 and 8.2
    pTextSym.Angle = 45
    pTextSym.Font = pFont
    pTextSym.Size = pFont.Size
    pTextElem.Symbol = pTextSym
    pTextElem.Text = "TestText"
    Dim pPoint As IPoint
    Set pPoint = New Point
    pPoint.X = 4
    pPoint.Y = 5.5
    Dim pElem As IElement
    Set pElem = pTextElem
    pElem.Geometry = pPoint
    pGC.AddElement pElem, 0
    '''''This is the workaround using angle...
    Dim pTwoD As ITransform2D
    Set pTwoD = pElem
    pTwoD.Rotate pPoint, 0
    pMxDoc.ActiveView.PartialRefresh esriViewGraphics, Nothing, Nothing
  5. Click Layout View from the View Menu.
  6. Click the new button to run the code. A new text element is added near the center of the layout. The element is rotated from the horizontal.
