English
Problem: TIN: Adding poly features with tags to large tin without tags takes too long
Adding points or polygons with tag values to a large tin that does not have tag values takes much longer than expected. The process appears to be hung although it really isn't.
Cause
This is a known problem.
Solution or Workaround
No solution at this time.
