PROBLEM
Programmatically adding RasterCatalogLayer to a MapControl or to ArcMap fails
When adding a RasterCatalogLayer to ArcMap or to a MapControl, programmatically, the RasterCatalogLayer does not display.
Cause
This is a known issue.
Solution or Workaround
This issue has been address in ArcGIS Version 8.1.2.
Article ID:000004384
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
