English
FAQ: Should the commands BUILDVAT, MERGEVAT and BUILDSTA work in the Raster Calculator?
Question
Answer
At ArcGIS 8.1.2, you can type the commands BUILDVAT, MERGEVAT and BUILDSTA into the Raster Calculator. For example:
Input dataset is located on disk:
Code:
BUILDVAT d:\data\ingrid
Inputs are in the working directory:
Code:
MERGEVAT in_grid merge_grid
Input dataset is a layer in the table of contents of ArcMap.
Code:
BUILDSTA [ingrid]
For more details on using the Raster Calculator, consult the ArcGIS Desktop Help: Spatial Analyst > Using the Raster Calculator > The Raster Calculator.
