English
Error: ORA-29855: error occurred in the execution of ODCIINDEXCREATE routine
Error Message
When indexing Oracle Spatial tables, like this:
SQL> CREATE INDEX Q2Q_POINT1_IDX
SQL> ON Q2Q_POINT1(SHAPE)
SQL> INDEXTYPE IS MDSYS.SPATIAL_INDEX;
The following error occurs:
ERROR at line 1:
ORA-13203: failed to read USER_SDO_GEOM_METADATA table
ORA-06512: at "MDSYS.SDO_INDEX_METHOD", line 7
ORA-06512: at line 1
Cause
In ALL_SDO_GEOM_METADATA, there is no row specifying this particular combination of OWNER, TABLE_NAME and (geometry) COLUMN_NAME.
Solution or Workaround
  1. Check for a row (mistakenly inserted into ALL_SDO_GEOM_METADATA) in which one or more of these columns is incorrect.
  2. Insert a new row into USER_SDO_GEOM_METADATA (a view of ALL_SDO_GEOM_METADATA) with the correct metadata.
