English
Problem: Extract grid by graphic sample script gives errors
The Spatial Analyst sample script, grextrct.ave, gives incorrect results.
Cause
The extent of the output grid is not properly set to that of the shape.
Solution or Workaround
Change the following lines of code:
  1. From:
    Code:
    ae = theView.GetExtension(AnalysisEnvironment)
    ae.SetExtent(#ANALYSISENV_VALUE, ashpext)
    ae.SetCellSize(#ANALYSISENV_VALUE, g.getcellsize)
  2. To:
    Code:
    grid.setanalysisextent(#GRID_ENVTYPE_VALUE,ashpext)
    grid.setanalysiscellsize(#GRID_ENVTYPE_VALUE,g.getcellsize)
