PROBLEM
If you save a map that contains a secure ArcIMS image service, and do not save the username and password with the connection, you will be prompted to login when you next open the map. If you click cancel on the login dialog box, ArcMap will crash.
This is a known issue.
Get help from ArcGIS experts
Download the Esri Support App
