PROBLEM
ArcScene: Unable to see full path to base surface if path string is long
If you set a base surface as a 3D property to a layer in ArcScene, you will not be able to see its full path if the length of the string exceeds the dropdown combo's width. The display of the path gets truncated.
Cause
This is a known limit.
Solution or Workaround
No solution at this time.
    Article ID:000004310
    Software:
    • ArcMap 8 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
