English
Problem: GRID IN operator has different results in 8.x than 7.x
At version 7.x, the IN operator returns zero, whereas at 8.x, it returns NODATA.
Cause
The documentation for IN states the following:
"If the ... value ... is not contained in the set specified by the second input, the location will receive NODATA on the output grid."
The result in version 7.x is erroneous.
Solution or Workaround
This problem was fixed in version 8.0.1.
