English
Problem: ArcScene: Extruded lines lose shading/lighting
Extruded lines lose proper shading when scene exported to an image, or when 'Render from data connection' is selected on the Rendering tab of the layer's Properties dialog.
Cause
This is a known problem.
Solution or Workaround
There is no solution at this time.
