English
How To: Label expression by way of VBScript
Summary
Instructions provided describe how to label expressions by way of VBScript. ArcMap provides a way to programmatically define the text that displays when labeling features.
This article contains sample code that show how to perform these common functions: case formatting, extracting a number, and stacking of labels.
Procedure
Right-click the layer and select Properties, switch to the Label tab, check the Label Features in this layer, and click Expression. In the Expression Properties dialog box check the Advanced option.
Copy one of the VBScript functions below into the Expression field.
Substitute the field [NAME] with a field that exists in your layer.
  • Convert field name to mixed case:
    Code:
    Function FindLabel ( [NAME] )
    ' Converts [NAME] to Mixed Case
    Dim t, newS, i
    t = [NAME]
    newS = UCase(Mid(t, 1, 1)) 'Upcase 1st char
    i = 2
    Do While i <= Len(t)
    ' check if previous char is a space
    If InStr(1, Mid(t, i - 1, 1), " ", vbTextCompare) > 0 Then ' space found
    newS = newS & UCase(Mid(t, i, 1))
    Else
    newS = newS & LCase(Mid(t, i, 1))
    End If
    i = i + 1
    Loop
    FindLabel = newS
    End Function
  • Extract a number:
    Code:
    ' Extracts number from [NAME]
    Dim sIn, sNew, i
    sIn = [NAME] ' input field value
    sNew = "" 'result
    i = 1
    ' check if char is numeric
    While i <= Len(sIn)
    If IsNumeric(Mid(sIn, i, 1)) Then
    sNew = sNew & (Mid(sIn, i, 1))
    End If
    i = i + 1
    Wend
    FindLabel = sNew
    End Function
  • Stack a label in multiple lines:
    Code:
    ' Stacks a label in multiple lines if
    ' exceeding a given length.
    ' Note: Not applicable to line layers.
    dim s, sNew, i, l
    s = [NAME]
    l = Len(s)
    if l > 10 then ' stack if exceeding this length
    sNew = Left(s,10)
    i = 11 ' scan for blank space starting from this position
    While i <= l
    if Mid(s,i,1) = " " then
    sNew = sNew & VBNewLine
    else
    sNew = sNew & Mid(s,i,1)
    end if
    i = i + 1
    Wend
    else
    sNew = s
    end if
    FindLabel = sNew
    End Function
    For more information, refer to the ArcGIS Desktop help topics: Labeling, Specifying text.
