ERROR
Unable to write tagged values to repository
Error Message
The Schema Wizard stops with a message:
"Unable to write tagged values to repository.
Element = ModelName
key=value schemacreated true.
Error number 3011."
Where 'ModelName' is the name of the UML model in the repository.
Cause
The Schema Wizard writes some information to the repository database in the form of tagged values.
If the repository is an Access database, then the file must not be read-only. If the repository is a SQL Server database, the user creating the schema must have write permissions to the database.
Solution or Workaround
Make sure the user running the Schema Wizard has write permissions to the repository database.
    Article ID:000004284
    Software:
    • ArcMap
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
