ERROR
When converting a geodatabase feature class to a coverage, the following message is produced when the tool completes the conversion:
"Execution Error An error was generated by ArcInfo while executing Layer Export. Would you like to see the output message? Yes No"Clicking Yes displays the following error, multiple times:
"SHAPE Error(25): Column value could not be converted into a number or date."This error is displayed at the end:
"ODE sub-process failed"
The geodatabase feature class contains null values in a numeric field. There is no equivalent for this in coverages. Hence, the error message occurs for each occurrence of a null value in the field.
[FIELD] is nullWhere FIELD is the field containing the null values.
Get help from ArcGIS experts
Download the Esri Support App
