Frequently asked question
What is MapObjects?
Last Published: July 7, 2020
Answer
The information in this article applies to a retired product.
ArcGIS is done with geoprocessing tools.
MapObjects is a set of mapping software components that enables the user to embed maps in applications. It is possible to combine MapObjects with components from other vendors, such as graphing, multimedia, and database objects. The applications built can be tailored to the specific requirements of the end-users.
MapObjects comprises ActiveX control (OCX), called the Map control, and a set of over forty-five ActiveX Automation objects. It is for use in industry standard Windows programming environments.
Programs built with MapObjects run on Windows 95, 98, ME, 2000 and Windows NT 4 or higher.
It is possible to implement the following and other functions in programs built with MapObjects:
  • Display a map with multiple map layers, such as roads, streams and boundaries.
  • Pan and zoom throughout a map.
  • Draw graphic features such as points, lines, ellipses, rectangles and polygons.
  • Draw descriptive text.
  • Identify features on a map by pointing at them.
  • Select features along lines and inside boxes, areas, polygons, and circles.
  • Select features within a specified distance of other features.
  • Select features with an SQL expression.
  • Calculate basic statistics on selected features.
  • Query and update attribute data associated with selected features.
  • Render features with thematic methods such as value maps, class breaks, dot density, charts, events or by Z values.
  • Label features with text from field values.
  • Create new shapefiles.
  • Draw images from aerial photography or satellite imagery.
  • Dynamically display real-time or time-series data.
  • Type in an address and find a location on a map.
  • Project data into different coordinate systems.
Article ID:000004268
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
