PROBLEM
When moving a vertex in the edit sketch, the line that rubberbands between adjacent points in the sketch may not appear, even though the vertex location is updated.
When a part of the edit sketch falls outside the map display, the rubberbanding between connected vertices is not dynamically updated.
Get help from ArcGIS experts
Download the Esri Support App
