English
How To: Replace one value for another within a field
Summary
Instructions provided demonstrate how to use the Replace function in the Field Calculator, to replace one value for another within a field in a table.
Procedure
  1. Load the table into ArcMap.
  2. Select Start Editing from the Editor menu.
  3. Open the table.
  4. Right-click the desired field.
  5. Select Field Calculator.
  6. Type the following in the expression box:
    Code:
    replace()
  7. Place the cursor between the parenthesis of the line just typed.
  8. Select the name of the field from the Fields list.
  9. Type a comma after the end bracket surrounding the field name.
  10. Type the value to be replaced and the replacement value; enclose each value in quotation marks and separate with a comma. For example:
    Code:
    replace([FLD_name],"Wisconsin","WI")
  11. Click OK.
