ERROR
ArcToolbox Warning: Feature class does not contain valid fields or feature table may be in use
Error Message
Some tools don't function properly if the input data is at the root of a drive (C:\myCov or D:\myShape.shp). The Define Mapping option is not permitted. This warning occurs:
ArcToolbox Warning
Feature class does not contain valid fields or feature table may be in use.
Cause
This is a known issue.
Solution or Workaround
Do one of the following:
  • Copy the data into a folder (C:\Data\myCov or C:\Data\myShape.shp). Use the tool or wizard on this copy of the data, then copy the data back to the root of the drive.
  • Move the data permanently into a folder (C:\Data\myCov or C:\Data\myShape.shp).
Article ID:000004241
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
