English
FAQ: Is a calibration map document available for ArcMap?
Question
Answer
Yes, there is an output calibration map document available for ArcGIS 8.x, 9.x, and 10. The file is called calibrate.mxd can be found in the following locations:
ArcGIS 10
<install_drive>:\Program Files\ArcGIS\Desktop10.0\plotters
ArcGIS 9.x
<install_drive>:\Program Files\arcgis\plotters
ArcGIS 8.x
<install_drive>:\arcgis\arcexe8x\plotters
If the default installation location was changed during the install of ArcGIS, then the above paths will be different based on this change.
