PROBLEM
When dragging any window within the application, or across ArcView from another application, the window leaves a trail. It takes awhile for the marks to go away and for ArcView to resume proper functionality.
The 'Show Window Contents While Dragging' and 'Use Transition Effects' options within the display effects are turned on.
You may need to restart your computer to see the changes.
Get help from ArcGIS experts
Download the Esri Support App
