PROBLEM
When using the IGDS to Coverage wizard, sometimes the output coverage has neither line nor point topology, nor does it join the ACODE file to the coverages FAT (Feature Attribute Table). This happens after the following options are checked:
· Build line and/or point attributes
· Join the ACODE file to associated feature attribute tables
Importing an IGDS level containing text elements will cause both the BUILD, and JOIN requests to be ignored.
This is a known issue.
Code:
JOINITEM [coverage_name].AAT [IGDS_name].ACODE [coverage_name].AAT [coverage_name]-id [coverage_name]-id ORDERED
Get help from ArcGIS experts
Download the Esri Support App
