English
Error: ArcToolbox Warning: Open feature class failure
Error Message
When using a tool from the Import to Geodatabase toolset, if a query is entered in the Query dialog box, the following warning will sometimes occur when the tool is run:
ArcToolbox Warning
Open featureclass failed
Cause
An incomplete query was entered.
Solution or Workaround
Before exiting the Query tab screen, click the Verify button to make sure the query expression is complete.
Related Information
