English
Error: ArcToolbox Warning: Create search cursor failure
Error Message
When using the Coverage to Geodatabase tool, if a query is entered in the Query dialog box, the following warning will sometimes occur when the tool is run:
ArcToolbox Warning
Create search cursor failed
Cause
An incomplete query was entered.
Solution or Workaround
Before exiting the Query tab screen, click the Verify button to make sure the query expression is complete.
Related Information
