English
Problem: Multipart polygons or lines can't be used as spatial filters to SeQuery in the ArcSDE 8.1 Java API
After setting the spatial filter of an SeQuery using the SeQuery.setSpatialConstraints() method, a subsequent call to SeQuery.execute() throws either a "numofpts is less than required for feature" or a "Polygon does not close properly" error. This problem only occurs when using multipart polygons or lines as filters to the query.
Cause
This is a known issue in the ArcSDE 8.1 Java application programming interface (API).
Solution or Workaround
There is no work-around for this issue.
