ERROR
Run-time error '326': Resource with identifier '3241' not found
Error Message
When using the SDTS Raster to Grid tool or SDTS Point to Coverage tool, and navigating for an input prefix in the floppy drive or CD-ROM drive, while they are empty, produces the following errors:
"ATAVConv
Resource with identifier '3241' not found"
"ArcToolbox Warning
An error occurred while browsing data"
Cause
The textual information required to populate the warning message (to indicate the drive is not accessible or empty) is incorrectly referenced.
Solution or Workaround
Avoid navigating with these tools to empty floppy or CD-ROM drives.
Article ID:000004201
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
