ERROR
Warning: File is not correct ArcToolbox format
Error Message
After saving to a batch file (*.bat) with the Raster to MrSid tool, attempting to load the file back into the tool produces a "File is not correct ArcToolbox format" warning. The file cannot be loaded into the tool.
Cause
This is a known issue with ArcGIS 8.1
Solution or Workaround
There is no workaround for this issue.
Article ID:000004199
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
