PROBLEM
In the Define Projection Wizard (coverages, grids, tins), if DS (degrees, seconds) is selected as the projection units, the dataset is assigned DMS (degrees, minutes, seconds).
This is a known issue.
Get help from ArcGIS experts
Download the Esri Support App
