PROBLEM
Having run the Define Projection Wizard (coverages, grids, tins) with certain Australian datums, the output dataset's datum will remain undefined.
The datums in question are:
AUSTRALIAN GEODETIC 1966 - Australian Capital Territory
AUSTRALIAN GEODETIC 1966 - Tasmania
AUSTRALIAN GEODETIC 1966 - Victoria
AUSTRALIAN GEODETIC 1966 (ICSM)
AUSTRALIAN GEODETIC 1984 (ICSM - 3 parameters)
AUSTRALIAN GEODETIC 1984 (ICSM - 7 parameters)
GEOCENTRIC DATUM OF AUSTRALIA 1994
This is a known issue.
Code:
/* Begin: Define Projection Wizard (coverages, grids, tins)
/* Aml script created with ArcToolBox tool: Define Projection Wizard (coverages, grids, tins)
/* Editing this file may make it unreadable to the ArcToolbox
Precision Single Highest
ProjectDefine COVER D:\wksp\covname
PROJECTION GEOGRAPHIC
UNITS DD
DATUM GDA94
PARAMETERS
/* End: Define Projection Wizard (coverages, grids, tins)
Get help from ArcGIS experts
Download the Esri Support App
