English
How To: Add an Annotation FeatureClass from a Personal Geodatabase to ArcMap with ArcObjects
Summary
Instructions provided describe how to add an Annotation FeatureClass to ArcMap. In this example the annotation resides in a Personal GeoDatabase.
Procedure
  1. Start ArcMap.
  2. Create a new UIButtonControl: How To: Create a new UIButtonControl
     For more information on creating a UIControl, see the ArcGIS Desktop Help topic 'Creating custom commands with VBA and UI Controls'
  3. Right-click the UIButtonControl and select View Source.
  4. Copy below code into the UIButtonControl's click event.
    Code:
    Dim strPathName As String
    strPathName = "D:\temp\yellowstone.mdb" ' Replace with the name of your Personal Geodatabase
  5. Modify the value of strPathName to reflect the location of your Personal Geodatabase.
  6. Copy the code below into the UIButtonControl's click event, immediately after the code you entered in Step 4.
    Code:
    Dim strData As String
    strData = "AnnoRoad" ' Replace with the name of your annotation FeatureClass
  7. Modify the value of strData to point to the annotation Feature Class in your Personal Geodatabase.
  8. Copy the code below into the UIButtonControl's click event, immediately after the code you entered in Step 6.
    Code:
    ' Set up the WorkspaceFactory
    Dim pWorkspaceName As IWorkspaceName
    Set pWorkspaceName = New WorkspaceName
    pWorkspaceName.WorkspaceFactoryProgID = "esricore.AccessWorkspaceFactory"
    pWorkspaceName.PathName = strPathName
    Dim pDatasetName As IDatasetName
    Set pDatasetName = New FeatureClassName
    pDatasetName.Name = strData
    Set pDatasetName.WorkspaceName = pWorkspaceName
    ' Use a lightweight Name object to open the table.
    Dim pName As IName
    Set pName = pDatasetName  ' QI
    Dim pTable As ITable
    Set pTable = pName.Open
    Dim pFeatClass As IDataset
    Set pFeatClass = ptable
    Dim pFeatLay As IFeatureLayer
    'IFDOGraphicsLayerFactory::OpenGraphicsLayer IS THE KEY to accessing the data!
    Dim pFDOGraphicsLayerFactory As IFDOGraphicsLayerFactory
    Set pFDOGraphicsLayerFactory = New FDOGraphicsLayerFactory
    ' Modify this line of code
    Set pFeatLay = pFDOGraphicsLayerFactory.OpenGraphicsLayer(pfeatclass.Workspace, Nothing, "AnnoRoad")
    'Assign the name in the Table of Contents
    pFeatLay.Name = pFeatClass.Name
    ' Add the annotation to ArcMap
    Dim pMap As IMap
    Dim pMxDoc As IMxDocument
    Set pMxDoc = ThisDocument
    Set pMap = pMxDoc.ActiveView
    pMap.AddLayer pFeatLay
    Dim pAV As IActiveView
    Set pAV = pMap
    pAV.Refresh
  9. Modify the third argument passed to the OpenGraphicsLayer method to point to the input annotation Feature Class.
  10. Test the code.
