HOW TO
Due to a Microsoft limitation, Dynamic Link Libraries (DLLs) with filenames longer than 128 characters do not register correctly with the following methods:
Warning: The instructions below include making changes to essential parts of your operating system. It is recommended that you backup your operating system and files, including the registry, before proceeding. Consult with a qualified computer systems professional, if necessary. Esri cannot guarantee results from incorrect modifications while following these instructions; therefore, use caution and proceed at your own risk.
Move the DLL to a path that has fewer than 128 characters. To keep the DLL in its current location, it is necessary to manually register the DLL using one of the following methods:
Note: If the Register option is not available on the Windows Explorer context menu, add it by running the registry script C:\Program Files\ArcGIS\DeveloperKit\Tools\Register_in_menu.reg.
Get help from ArcGIS experts
Download the Esri Support App
