English
Error: Access exception
Error Message
After installing a Matrox Millenium video card in dual-head mode (dual monitors), ArcScene crashes with Dr. Watson error.
Cause
The Matrox Millenium card's 3D Acceleration setting may cause problems with ArcScene.
Solution or Workaround
Disable the 3D Acceleration setting for your Matrox Millenium video card .
  1. Right-click the background of your display and select Properties.
  2. Locate the Matrox properties and under Performance uncheck 3D Acceleration.
  3. Reboot your machine.
  4. Start ArcScene.
