PROBLEM
Plots clip since upgrading operating system
After upgrading the operating system, plotting a project produces clipped output.
Cause
The new operating system has new printer drivers. These new printer drivers may have different margin settings, which result in clipping of existing projects that have static layouts.
Solution or Workaround
Create new layouts on the new operating system so ArcView will use the margin settings of the new operating system drivers.
A clipping problem can sometimes occur due to reducing the margins within ArcView. DesignJet driver margins are an absolute minimum. You should not enter values less than these even if ArcView allows you to in the Layout Page Setup.
Article ID:000004142
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
