PROBLEM
After joining tables, the field names appear but the attribute data does not
When joining tables in ArcGIS, the field names will come across, but the attribute data is missing.
Cause
The source table has a space in the name of the file.
Solution or Workaround
Rename the source table to correct the space error in the file name.
Article ID:000004133
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
