English
Error: Assertion ("self->bounds"->right-self->bounds"=>) failed at 368 of file "..\glist\gsbar.c"
Error Message
This error occurs when selecting Layout from the View menu and selecting a template in the Template Manager:
assertion ("self->bounds"->right-self->bounds"->) failed at 368 of file "..\glist\gsbar.c"
After clicking OK, a DOS window appears with the following second error message and then ArcView disappears:
traceback:
module "avarray" message 0: file ".\err.c " line 645
module "obj" message -1:file"..\objm\obj.c" line 791
module "appl" message -1: file "..\appl\appl.c" line 1639
module "err" message -1: file ".\err.c" line 2009
Cause
A customized template.def file is corrupt.
Solution or Workaround
  1. Search your hard drive for the file 'template.def'.
    A customized 'template.def' file is usually located in the $HOME directory.
  2. If a file is located in a directory other than the default C:\ESRI\AV_GIS30\ARCVIEW\ETC directory, rename it to 'templateold.def'. This will force ArcView to use the default 'template.def' file when creating a layout.
