English
Error: The ODBC resource DLL (C:\WINNT\system32\odbcint.dll) is a different version than the ODBC driver manager (C:winnt\system32\odbcint.dll)
Error Message
This error occurs when installing Peer Web Service:
"ODBC Driver Manager: the ODBC resource DLL (C:\WINNT\system32\odbcint.dll) is a different version than the ODBC driver manager (C:winnt\system32\odbcint.dll) You need to reinstall the ODBC components to ensure operation. Press OK to proceed. Cancel to abort."
Cause
Installing Peer Web Service on Windows NT Workstation 4.0 will overwrite the odbcint.dll and the odbccp32.dll files with version 2.50.30.6 of these files. This causes the version conflict message.
Solution or Workaround
Warning:
The instructions below include making changes to essential parts of your operating system. It is recommended that you backup your operating system and files, including the registry, before proceeding. Consult with a qualified computer systems professional, if necessary.
Esri cannot guarantee results from incorrect modifications while following these instructions; therefore, use caution and proceed at your own risk.
Replace the odbcint.dll and odbccp32.dll files with copies of the files from a system that does not have the Peer Web Service installed.
The original files have the following specifications:
odbcint.dll    Size: 66kb
               Date: 6/12/97 10:32 AM
               Version: 3.0.2822
odbccp32.dll   Size: 86kb
               Version: 3.0.2822
