English
How To: Print symbol palettes
Summary
This article shows how to print out all the various symbol palettes (fill, pen, marker, font, or color).
Procedure
The following will place the desired palette in a layout. You can then print the layout.
  1. Load the 'symdump.ave' sample script into a new script window.
    A. Select 'Load Text File' from the Script menu.
    B. Navigate to the ..\esri\av_gis30\arcview\samples\scripts\ directory.
    C. Select the script and click OK.
  2. Click the Compile button.
    [O-Image] Script compile button
  3. Click the Run button.
    [O-Image] Run compiled script button
    To learn more about the above script, see the online help topics: Index tab > Samples > Scripts. Click the Display button and scroll through the Topics Found box to find Layout.SymbolDump.
