PROBLEM
Occasionally errors can arise when trying to connect to a database on an AS/400 using a HIT Technologies driver.
This is due to an incompatibility with the winsock32.dll in the Arcview startup script.
Code:
if (FN.FindInSystemSearchPath("wsock32.dll) <> nil) then
System.LoadLibrary("$AVBIN/avrpc.dll".AsFileName)
end
Use Windows Explorer to make sure the text editor did not add a .txt extension to the file.
Get help from ArcGIS experts
Download the Esri Support App
