English
Error: Create: An Unexpected failure occured. Underlying DBMS error CLI0100E ...
Error Message
After loading a layer using DB2's Spatial Extender Control Center, the following error message occurs when creating new features in a DB2 SDE geodatabase feature class:
Create: An unexpected failure occurred.
Underlying DBMS error CLI0100E Wrong number of parameters.
SQLSTATE=07001::07001
Cause
Logic problems in calculating the bind parameter number for S_bind_column.
Solution or Workaround
Download ArcGIS 8.1 Service Pack 1.
Related Information
